Objects No Longer Move When Expanding Structures
When I initially started coding in the LabVIEW environment, the structures within the block diagram caused other objects to move when expanding the structure. Now the objects don't move when expanding structures. Is there an option or keyboard shortcut that I may have pressed to cause this feature to disable? Here is a picture of what structures currently do when attempting to expand them.
(2,214 Views)
Accepted by topic author adequitz
Hi adequitz,
right-click the structure and check its "Autogrow" property!
(We could have done that too if you had attached your VI instead of an image showing just a part of the block diagram…)
There also is an generic Autogrow setting in the LabVIEW options…
(2,210 Views)
Thanks GerdW!
(2,202 Views)
