OPC UA client cannot connect to PLC
Hi there,
Has anybody used the OPC UA client that is part of the DSC toolkit? I am trying to use it to connect to a PLC and am getting error -336653 "The status of the OPC UA server is uncertain"
I am able to create a local OPC UA server in LabVIEW and connect to this with no issues from the LabVIEW OPC UA client, and can connect to the PLC just fine using a different client.
After speaking with NI it looks like this may be a permission issue, but I have tried all the obvious things in the OPC UA client (like client and server certificates), with the same result.
Any tips?
(4,491 Views)
we've developed an OPC DA 3.0 client in Labview and we had similar problems.
Then we added "ole.AuthnLevel=1" in the LabVIEW,ini file (and in the built exe application) and it worked.
Maybe this also helps you ...
Best regards
Hans
(4,239 Views)
Hello
Have you resolved the Problem with the ole...?
(3,049 Views)
It was fixed for me by using an updated version of the OPC UA client DLL which NI provided. This was back in 2015 so I presume the fix has been rolled into the most recent version.
(3,040 Views)
