Network Streams error -314350 | Many executable to One executable communication issue
Hi all,
I have an application which communicates using network streams.  My applications are designed in a way that
  • there is one receiver (data aggregator) which gets data from all data senders.  I have used read network stream nodes in this executable.  There is logic in this receiver to generate required number of read-stream endpoints in order to connect to each new sender.
  • there are two or more senders which sends data to that single receiver.  I have used write network streams nodes in these executables.
In LabVIEW environment, when I simulated this scenario of one receiver and two sender, the communication is very fine.  Whereas, if I do it in executable mode, only the communication is bridged between first sender and the reader.  If the the secnod sender tries to connect to the receiver, I get the error −314350
−314350 Another application is already streaming data to an endpoint in the context you specified. If you specified a context name in the reader name or writer name terminal of the endpoint, you must specify an unused context name. If you did not specify a context name, you must specify an unused context name by entering an endpoint URL in the reader name or writer name terminal.
I have attached the sample I used for testing this.  Below is the animation of the error.
Why does this error occurs here?  Is that network stream allows only one endpoint in an executable?
Error In Executable:
No Error In LabVIEW Environment:
Ajay.
Ajay MV
(7,195 Views)
I think you have specified the wrong endpoint URLs in your application - specifically, the 'context_name'.
See the forum post here and the NI documentation here.
(blog)
(7,181 Views)
Accepted by topic author Ajay_MV
I think the problem here comes from the fact that you are not taking care of the names of executables in the stream name definition. Tho correct way to construct a name of the stream you want to connecto to is:
//IP:ApplicationName/ReaderOrWriterName
ex. //localhost:MyReaderApp/Reader
This is because the network stream engine needs to be able to find the app you want to connect to on the system.
More details here:
https://forums.ni.com/t5/LabVIEW/Network-streaming-stand-alone-application/m-p/2464202#M755351
https://www.ni.com/docs/en-US/bundle/labview/page/specifying-network-stream-endpoint-urls.html
These requirements also apply when using Reconnecting Network Streams. They simplify this a little but because they have a mechanism to determine the right context(app name) for an application, but you still need to provide that context on the other side of the stream.
In LabVIEW they will work correctly because the LabVIEW context is known by default. Any other context needs to be specified.
Does this help?
Piotr Kruczkowski
Certified TestStand Architect
Certified LabVIEW Architect
(7,177 Views)
@Sam_Sharp & @Poitr,
Thanks both of you 🙂 .  You are correct that I missed exactly "Context name" of the streams.  When I gave the stream names as below, the issue got fixed and works fine.
//localhost:Receiver/Reader
//localhost:Sender/Writer
//localhost:Receiver/Reader new
//localhost:Sender New/Writer new
I'm yet to do this in my main application code.  I will keep posted if I'm facing any more issues.
I hereby attached the issue fixed code for reference.  Anyone having similar issue may correlate my previously posted code and this code.
Thanks again for this help,
Ajay.
Ajay MV
(7,156 Views)
have had the same problem. in my case i figured out that it is also Importend to give the right reader name. Taking care of the write name is not enought. I build a connection between 2 computers, see the atached picture for the configuration
(4,682 Views)
