NI cRIO-9073 connection (software error)
I tried to connect to the cRIO using MAX. But there is software error (as shown in picture MAX). What shoud I do?
Regards
(5,348 Views)
Dear Sljukaa,
The above picture shows your cRIO-9073 Dip Switch status. If you check Dip switch 1 is related to safe mode.
So to move out your cRIO out of this safe mode switch off this dip switch 1 and reboot the RIO.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(5,342 Views)
Dear Himanshu Goyal,
I did that but in project explorer I can't see Chassis and modules (picture "Project explorer") and I can't choose between Scan Interface or Labview FPGA Interface because I don't see Select Programming Mode dialog.
Do You know what is a problem?
(5,334 Views)
suggets you try deleting the chasis from the project and then install new.
Do this by highlighting **.lvproj then right click mouse select /New/target and devices. Program should then self find the chassis, might need to help it with reference to Ip address.
hopefully you'll ber good to go!
/xseadog
(5,303 Views)
Accepted by topic author Sljukaa
Dear Sljukaa,
You are working with the cRIO. So the modules list will may not come in MAX. To identify the problem create a FPGA application and descover the c Series modules in LabVIEW. You will get the module list in FPGA parent in Tree. If still you feel some issue to detect the module Open your LabVIEW INI file and copy past "cRIO_FavoriteBrand=generic" line.
Thanks and Regards
(5,296 Views)
Great, it works!
Regards
(5,286 Views)
None of the solutions worked for me. I found out my problem was I installed lots of software on the cRio and was running out of memory. Once I installed only what I needed, everything worked just fine.
(4,015 Views)
