08-14-2015 11:53 AM
@DailyDose wrote:
The image I attached in an earlier post shows the VIs in my Utilities pallet. My list of VIs appears to be incomplete based on that link you posted.
"Real-Time Module. This topic might not match its corresponding palette in LabVIEW depending on your operating system, licensed product(s), and target."
Is your RealTime version up-to-date?
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
08-14-2015 01:27 PM
So... I contacted NI Support. Turns out, in order to see all RT VIs, you must be programming a VI under the RT target in the Project Explorer. So, for future reference kiddos... learn from my mistake. Right click Project; New; Targets and Devices; New Target or Device (assuming there is no existing target); Expand Real-Time CompactRIO; Select appropriate type. Now make VIs under the target and all VIs will become available in the Pallette.
08-14-2015 01:31 PM
haha, gosh I could have told you that. The compiler doesn't know what target you're on otherwise and the palettes change to match the target. Good stuff.
Cheers
08-26-2015 04:08 PM
Hey there, so with initial tests, the Memory VI available for RT doesn't appear to be the type of Memory I was thinking. I made a very simple test. I created a constant timed loop to measure the memory while writing to an indexed tunnel. The idea, as the tunnel increases in data, it should allocate more memory. I did not see any changes in the memory. Is this VI not necessarily what I thought it was? Just simply how much space is left on the target for more code?
08-26-2015 05:38 PM
From what I know, you can't view the buffer memory statistics on the cRIO. This seems to point to the System Manager being able to show you, but that's the only place I can find what it sounds like you're looking for.
RT Get CPU Loads can show you a bit of statistics regarding how bogged down your RT target is, but not the memory usage.
Cheers
