10-24-2013 06:06 AM
Hello All,
I have one pc where I installed Access 2010 Full version and one pc with a Access Runtime.
On the pc with the full version i can create a ActiveX "Access.Application" Class and run all
properties and methods.
That's not possible with the Runtime version. The Reference to the ActiveX Access Runetime is always Null.
I found this side http://support.microsoft.com/kb/210132/en-us to solve the problem, but I didn't know
how to create such a source code in labview.
In the false case of my VI you see the runtime method, but I do not know how to continue
at this Point (relating to the link):
Run-Time Version of Microsoft Access
4. Type the following procedure
Does somebody know how to create the "GetObject" Method in labview?
Thanks!
10-25-2013 08:38 AM
Did you have a look into this whitepaper? I think you can find some usefull help there.
http://www.ni.com/white-paper/2734/en
Thomas
10-25-2013 09:19 AM
Thanks for reply.
Yes I know it but it didn't help.
I wrote me an VBScript and call it over System Exec.vi with the service WScript.exe.
Until now, noone could help me with this issue, also in other discussion boards.
11-29-2013 07:10 AM
Sorry, but I can't help you, is a serious problem, or this has not solution for now.
