Looking for Agilent/Keysight/HP 6634B LabVIEW Drivers
Hello everyone,
I have tried seraching everywhere but I can't find the labview drivers for the  Agilent/Keysight/HP 6634B power supply. The only ones I can find are for the 6xxxA series, but not the 6xxxB series.
If anyone has them or knows where to find them I would be very grateful!
Message 1 of 9
(5,480 Views)
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E947E659CE034080020E748...
Or you can create your own driver using the SCPI command list which you can find in the manual...
Message 2 of 9
(5,477 Views)
Thanks for replying.
These aren't the LabVIEW drivers. These are just just some automated update software!
Message 3 of 9
(5,474 Views)
Accepted by topic author quantisedpenguin
You are in a mistake. That is indeed the LabVIEW driver, IVI class type. If you do not like that this driver calls DLLs, as I wrote above, you could just create your own driver pack following the SCPI information located in the manual of your device...
If you want to use the available driver, follow these steps:
  1. Download and install IVI package for your LV version: http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/n8:3,ssnav:ndr/sb/-nigenso4-...
  2. Restart PC
  3. Install the IVI driver from this site: http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E947E659CE034080020E748... (direct link for the exe: http://sine.ni.com/apps/utf8/niet_download_id.log_ids?p_profile_id=1270941&p_doc_id=E3B19B3E947E659C... )
  4. Enjoy:
Message 4 of 9
(5,466 Views)
Oh wow, I didn't see this when I first tried installing that package. This is great, thank you!!
Message 5 of 9
(5,458 Views)
No problem, good luck with your project! 🙂
Message 6 of 9
(5,455 Views)
What about HP6632A? Where can I find Labview drivers for it? I'm using Labview 14.0.
Thank you.
Message 7 of 9
(5,164 Views)
Thank you.
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=014E5475A4556F51E0440003BA7CCD...
Message 8 of 9
(5,162 Views)
Thanks, Blokk. I also found it. I found this page useful too:
http://www.ni.com/tutorial/2804/en/
Best regards.
Spring.
Message 9 of 9
(5,152 Views)
