05-06-2024 07:26 AM
Hello everybody,
I would like to silent install LabView V21.0 with this commandline: \install.exe /q /acceptlicense yes, but everytime I get this message "The command-line includes one or more obsolete options, Remove /q from the command line"
When I remove the /q part, the license is not auto-accepted. In the older versions of LabView I just used setup.exe /q /acceptlicenses yes /r:n without any problems.
Is this a bug in the installerfile?
Thanks, Michel
Solved! Go to Solution.
05-06-2024 04:34 PM
Just to make sure, have you tried with "/acceptlicenses yes"? I noticed your first one said license instead of licenses.
05-07-2024 01:34 AM
Hi Gregory,
Thanks for your reply.
I also tried that, with the same result.
I'm not sure if the commandline is casesensitive thus I also tried /AcceptLicenses yes
So, the final result for now is that I see the licenseagreements screen on my desktop.
05-07-2024 10:23 AM - edited 05-07-2024 10:26 AM
As LabVIEW 21.0 is a Package Manager-based installer, the command-line parameters have changed. These are now the instructions for silent\unattended installation:
https://www.ni.com/docs/en-US/bundle/package-manager/page/automate-installer.html
05-08-2024 06:26 AM
Thanks WesW, it's working!
