LabVIEW App Builder
I successfully built an application and needed to make some corrections to the code and want to do another EXE Build - now I am getting the following error!
What is causing this?
NI_FileType.lvlib Error Copying Files
LabVIEW 2009
Error copying files.
Source: C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\Utility\lvfile.llb\NI_FileType.lvlib
Destination: C:\Projects\S\SuperiorWellServices\20090032\SourceCode\New Shell\NODE\propPORT_I\propPORT_Builds\propPORT_I_EXE\propPORT_I.exe\NI_FileType.lvlib
Invoke Node in AB_Source_Library.lvclass:Copy_SourceItem.vi->AB_Build.lvclass:Copy_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_EXE.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_EXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
Details:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 8 occurred at AB_Source_Library.lvclass:Copy_SourceItem.vi -> AB_Build.lvclass:Copy_Files.vi -> AB_Application.lvclass:Copy_Files.vi -> AB_EXE.lvclass:Copy_Files.vi -> AB_Build.lvclass:Build.vi -> AB_Application.lvclass:Build.vi -> AB_EXE.lvclass:Build.vi -> AB_Engine_Build.vi -> AB_Build_Invoke.vi -> AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW:  File permission error. You do not have the correct permissions for the file.
NI-488:  DMA hardware error detected.
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
(4,156 Views)
Accepted by topic author RVallieu
I have this error before and did see a KB article that talks of something similar:
Why do I get "Error 8 Occurred at Open File" When Writing to or Reading From a File?
Try to build after closing all files on your machine. I would also recommend restarting the computer. It seems like this is an intermittent error that shows up during application build.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,151 Views)
Or another trick is to specify the builder to place your code in a short path (eg. c:\bld), With the new layout LabVIEW quite easily runs into the 256 character length for a path.
Ton
My LabVIEW Ideas
(4,147 Views)
I was just about to post - after the 5th time I shut down LV completely and restarted it the build is working again....
(4,141 Views)
