LabVIEW 2013 Window Appearance
Hi folks
I'm facing a new problem since I've installed LabVIEW 2013. I configured my main application window to hide both toolbar as well as the scrollbars. The window appears as the attached screenshot demonstrates. Instead of the (hidden) toolbar a white bar shows up, by the same height as the toolbar actually would have. Same issue with the scrollbars. After creating an exe file the problem disappears in matters of the scroll bars. The toolbar has the same problem as it had before.
You can see the window appearance configuration in the second screenshot. The application itself has not changed, I just updated from LabVIEW 2012 to 2013.
Anyone else noticed this, too?
Thanks for any feedback!
Message 1 of 14
(4,855 Views)
I see that you still have the option to display the abort/run/... buttons.
What happens if you uncheck those options (and rebuild the EXE)?
Norbert
Norbert
Expert: Geometry
Message 2 of 14
(4,818 Views)
Hi Norbert
This approach brings me the same issue.
Message 3 of 14
(4,795 Views)
Can you check if this also happens if you create a new project in 2013 with a "dummy"?
Norbert
Norbert
Expert: Geometry
Message 4 of 14
(4,772 Views)
Hmm, when I create a dummy VI the problem does not appear. Neither when I copy the whole VI into a new one. This causes some work but is possible. Looks like a corrupt VI??
Message 5 of 14
(4,733 Views)
@BrotherTom wrote:
[...] Looks like a corrupt VI??
Not necessarily. Did you take your original project and try to create a completly new build spec in it?
Maybe its a "corrupt" build spec....
Norbert
Norbert
Expert: Geometry
Message 6 of 14
(4,730 Views)
This cannot only be a corrupt build specification because the problem occurs also when I run the VI within LabVIEW without creating an executable.
Message 7 of 14
(4,713 Views)
I have heard many similar complaints.  I think it's some sort of graphics glitch.  Some complain about a black toolbar.  With some, it's a corrupted-looking toolbar.
Bill
CLD
(Mid-Level minion.)
Message 8 of 14
(4,693 Views)
does the VI work now?
Was you able to build an exe?
Richard
Message 9 of 14
(4,577 Views)
Hi Richard
I haven't seen your post until now... I'm sorry!
The problem is still persistent, with and without executable. But accidentally I found out what triggers the problem:
VI Properties --> Window Appearance:
Disable "Show Toolbar when running" and both "Show Scrollbar" and don't allow the user neither to close nor resize the window.
VI Properties --> Window Size:
Define a fixed window size.
VI Properties --> Window Run-Time Position:
Define a fixed Run Time Position (e.g. "Centered") and don't check"Use Current Panel Size".
Anyone can reproduce this issue using LabVIEW 2013? Attached you'll find an example VI.
Message 10 of 14
(4,527 Views)
