02-10-2012 04:50 PM
When trying to save bug.vi, I get a LabVIEW crash. To reproduce this, open bug.vi, connect "cluster in" somewhere on the connector pane, and save. If that doesn't cause a crash, please let me know! If it does cause a crash, please tell me how to work around it!
George
02-10-2012 05:03 PM
Work around using flatten/unflatten to string. Definitely a bug!
02-13-2012 06:53 PM
Hi George - Thanks for reporting this! I've reproduced the error and will be investigating it; I'll keep you updated with any progress made.
Just to confirm- what version of LabVIEW are you running and what OS are you using? I just want to make sure I'm seeing the same thing as on your end.
02-13-2012 06:57 PM
Interesting! About two weeks ago, I submitted some code that used Create Network Stream Endpoint Reader. If you expanded a Concatenate String function from two inputs to three and wired it, you got the "Sorry for the Inconvenience" error. A definite bug (reported to and logged by NI). Fortunately, an App Engineer told me how to prevent the crash -- remove a While loop that was part of the code, edit away, then put the While loop back. Totally weird!
02-14-2012 09:34 AM
Hi Tom
I am running LV 2011 32-bit on Win7 64-bit. I have successfully worked around the issue for now by inserting the flatten/unflatten operation in the wire, but I would like to remove that and save the performance hit, so definitely let me know if anything happens with the issue.
George
02-14-2012 05:37 PM
This was reported to R&D (# 338146) for further investigation. For now, the workaround you suggested using the flatten to/unflatten from string seems to work well. Thanks for the feedback!
07-06-2012 03:35 PM
Hello, has any progress been made on this issue? I have a VI I pass a cluster into and get the error cluster out. Everything works fine until I try and collect the error cluster once the subVI has finished. Then when I try and save LabView crashes.
Ed
07-06-2012 08:23 PM
I reported the original bug, and haven't heard anything back. I did have a chance to see if the bug was present in the 2012 beta, and it is ...
Let's hope that it's fixed by August!
BS
07-09-2012 03:13 PM
I have checked in on the bug that you mentioned, and it is scheduled to be fixed in the release version of LabVIEW 2012. However I can not guarantee that this will fix the bug in your specific applications.
~jp
