LabSQL Error
Hello all,
I am trying to connect to a database created by MS Access through LabSQL (yes, I know it's archaic and comes with no support but the LV Database Connectivity Toolkit just isn't an option on my student budget Smiley Tongue )
I used a connection string from www.connectionstrings.com/access-2007, and the string is as follows: Provider=Microsoft.ACE.OLEDB.12.0;Dbq=C:\Users\Laura\Simulation\Polar Bear Window & Door Manufacturing LTD\1500A Awning NFRC Report\W6- Awning 1500A.mdb;Uid=Admin;Pwd=;
The error message I am recieving is "Exception occured in Microsoft Access Database Engine: Could not find installable ISAM. in ADO Connection Open.vi->Untitled 1"
Attached is a snip of my VI for more info.
Thanks!
Laura
Message 1 of 10
(5,172 Views)
Are there spaces in you mdb filename? If so, that may be causing the connection problem.
Message 2 of 10
(5,163 Views)
There were, but I deleted all spaces in the filename (and even the path to be safe), but still the same error!
I found this Microsoft KB article about the error: http://support.microsoft.com/kb/318161
Maybe you LabView experts can find a way to relate this to LabView!
Message 3 of 10
(5,160 Views)
You are not using Jet.
Do you have Access 2007 installed?
Message 4 of 10
(5,151 Views)
I have Access 2003 (32 Bit) installed.
Message 5 of 10
(5,145 Views)
Then your connection string is wrong.
You need the one for Access and not Access 2007.
Message 6 of 10
(5,140 Views)
Either way the provider is Jet 4.0, is it not?
Message 7 of 10
(5,117 Views)
Uh, no.
Message 8 of 10
(5,110 Views)
Instead of some connection string you found somewhere, create one from scratch with a udl or create a dsn in the ODBC Data Source Administrator. You can validate it there and know it is working before trying it with LabSQL.
Message 9 of 10
(5,107 Views)
The connection string at ConnectionStrings.com are correct, but you have to know which one to use.
Message 10 of 10
(5,103 Views)
