Interface AC power source
I have recently bought an AC power source from LISUN GROUP (LSP-500VAR) as i tried interfacing it with labview the device was not responding but when i used the system given software( which is not on labview) it was working. It is communciating using Rs232.
Please help
Message 1 of 23
(4,670 Views)
Does the manufacturer have a manual that tells you how to use it via RS232?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 23
(4,624 Views)
the manufacturer has given communication protocol for various operations.
The manufacturer has not provided any drivers for the device will that cause a problem in communication.
Thank You
Message 3 of 23
(4,619 Views)
Hi naman,
start with the "Basic Serial Read and Write" example VI coming with LabVIEW.
Send commands as described in your manual and check devices answers according to your manual…
Message 4 of 23
(4,567 Views)
i tried the same, i am attaching the pic of the block diagram kindly let me know if there is error, the problem is the device is not responding or giving back data
Message 5 of 23
(4,565 Views)
Hi naman,
when the manual states "send byte 0x15" you need to send exactly that byte. Right now it seems you send 4 bytes "0", "x", "1", and "5" which is wrong!
Set your string constants to "hex display" mode and input the needed byte values then!
Setting a timeout of 1000s (or >16min) is also not recommended…
Message 6 of 23
(4,552 Views)
i tried the same but still no communication, will it play any role if we dont have the device drivers for the device as the company is not working in labview
Message 7 of 23
(4,549 Views)
Hi naman,
as long as you have a (good) programming manual you can write your own device driver VIs.
You only need to know the exact parameters of the communication protocol!
Message 8 of 23
(4,544 Views)
@GerdW wrote:
Hi naman,
I'm going to add that the "0x" isn't part of the code you should send.  That's just telling you that the following number is a hex number.
Bill
CLD
(Mid-Level minion.)
Message 9 of 23
(4,525 Views)
Please attach the manual and an image of your current block diagram. You also need to make sure that the vendors software is not running.
Message 10 of 23
(4,506 Views)
