10-04-2011 01:26 PM
I built software using LabVIEW 2010 in Windows 7 Pro, 32-bit. My customer is running Windows 7 64-bit. On attempting to install my software, he gets the following errors:
The "NI VC2008MSMs x64" installation has failed with the following error: Error 1935. An error occurred during the installation of assembly component {53EF73B0-18B5-32DE-B765-B5F7FSD69550}, HRESULT: 0x80070BC9. Continue?
This error pops up a couple of times related to different assembly components, and it also complains about the "NI VC2008MSMs x86" installation. Any ideas?
Thanks!
11-28-2013 11:50 PM
Same problem here with Windows 7 x64. The component that's being installed only seems suitable for x86 ... should I be installing different versions?
12-02-2013 08:45 AM
Hi mikejt4
Try following the steps recommended from this Microsoft knowledge base article:
http://answers.microsoft.com/en-us/windows/forum/windows_vista-windows_programs/error-code-1935/ac31...
Make sure to run the installer as or with admin priviledges
