03-02-2011 10:04 AM
03-02-2011 10:30 AM
Any words to go with your title?
I'm going to assume that you are trying to say you don't have the Instrument I/O assistant installed and want to know how to install it.
Have you installed the VISA drivers following your LabVIEW installation.
03-02-2011 10:44 AM
I installed Labview 2010,when tried to use Instrument I/O Assistant it told me it is not installed correctly,
I installed it and install it again twice because I am getting the same error,I have VISA and NI-488.2 Drivers installed. Thank you
03-03-2011 01:09 PM
Zack,
It sounds like you are following along with the knowledgebase article How Can I Fix an "Instrument I/O Assistant Not Installed Properly" Error? which is good.
Are you trying to install from the driver device CD or from a file that you downloaded from NI.com?
Do you get any errors while uninstalling the instrument I/O Assistant before you try to install it again?
03-03-2011 02:06 PM
Thank you for response, I am trying to install it from a file downloaded from NI.com, I am not getting any errors while I am uninstalling it, but after the installation I am getting that it is not installed correctly I do not know how to get it don. Thank you
03-03-2011 03:16 PM
I would recommend going to to your control panel >> programs and features >> and then right click National Instruments Software and select Uninstall/Change and remove NI-VISA, NI-488.2, and NI Installation I/O Assistant.
Next install NI-VISA (and NI 488.2 if you are using GPIB). There should be an option to install NI Installation I/O Assistant along with it. (I would suggest the 5.0.3 version which is current for LabVIEW 2010 as of March 2011) This can be found at NI-VISA 5.0.3
If you are unable to install the NI Installation I/O Assistant from the NI-VISA installer then we'll probably have to go to the Device Driver download.
03-04-2011 08:15 AM
Thank you,it is working now.
07-26-2012 02:49 PM
I am trying To write a driver for my signal generator since I could not find that specific driver in Labview search driver. I am thinking to installed instrument I/O assistant for this task. Or do you have better idea. I am very new using labview. can you provide me with the link to install Instrument I/0 assistant
07-27-2012 01:36 PM
Hi Khoury,
It’s always better to open your own discussion forum in order to provide you better assistance.
In this case you will find in this link more information related to the Instrument I/O Assistance.
I hope this helps!
08-10-2012 05:46 PM
I have a similiar problem, however, I downloaded LabView straight from NI through my school. I don't have a disk to install the Instrument I/O Assistant. Do you know where else I can download the driver?
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
