Hyperlink to another sheet
Hello Everyone
I am trying to create a hyperlink in a cell to another sheet in the same workbook. Preferrably the name of the sheet tab is the name of the hyperlink.
I am using LV 2010. It can be using the report generation toolkit or not.
Any help is appreciated.
xxxMidna19
(3,668 Views)
Hi Midna,
I haven't been able to find any examples that accomplish this. We have a community example for creating a hyperlink in a cell in Excel via Active X. In this implementation, you need to give the address as a string. In order to modify this to link to another cell, you would need to find out if ActiveX has a way to format an address to another cell as a string. This should be standard to ActiveX.
I'm not sure that this will be possible to implement using ActiveX controls in LabVIEW, but I suggest you try starting with Microsoft documentation for ActiveX for Excel.
I hope this helps!
Emily C
(3,625 Views)
Hi Emily C.
Thanks for responding!
I want to modify this VI and hyperlink from the cell to another worksheet inside the same file. Is there a way to do this? I feel like you just neek to change
the invoke node under hyperlinks but I really don't know.
xxxMidna
(3,607 Views)
Hi Midna19,
I have not been able to find any documentation or examples for accomplishing this. If there is a way to do this, it would be through standard ActiveX functions. I suggest you try starting with Microsoft documentation to find out if there is a way to use ActiveX to create a hyperlink to a cell in a worksheet. If there is a way to do this through Excel, you should just need to determine the right format to be able to modify this to connect from LabVIEW.
Thank you,
Emily C
(3,575 Views)
Accepted by topic author Midna19
This works for me (I edited the VI in the link provided by Emily-C):
One way to figure out how to program something in Excel is to record a macro while manually doing what you're trying to accomplish programmatically.  Here's the macro that resulted when I created a hyperlink to a cell in the same document:
Sub Macro1()
' Macro1 Macro
    Range("A9").Select
    ActiveSheet.Hyperlinks.Add Anchor:=Selection, Address:="", SubAddress:= _
        "Sheet2!A5", TextToDisplay:="Recorded"
End Sub
This clued me in to the fact that the Address needed to be an empty string and the SubAddress should be the Sheet!Cell of the target.
Jim
(3,567 Views)
Thank you jcarmody!  😄
I have been trying to figure out this for a while now.
It worked and thanks also for the intro to Macro. I had no idea how to go about it.
xxxMidna
(3,540 Views)
