How to plot 3D surface graph from X,Y,Z points?
Hi all,
Need to plot a 3D surface from X,Y,Z 1D arrays.  This works when plotting as points but I want to form surfaces between the points.
I am thoroughly confused about the formation of the 2D Z matrix required by 3D plot surface helper.  How to form the Z array (2D)?
Attached is a VI with typical (default) data.
Thanks to all.
Battler.
Message 1 of 34
(37,039 Views)
You must interpolate the surface prior to graphing it. I'm working on an example right now...
Message 2 of 34
(37,020 Views)
Here's a screenshot of the VI: for licensing reasons I cannot upload a working version of the code. It should be easy enough to reconstruct. The 3D polynomial fit and evaluation VI's (the ugly subVIs with black text on white) can be downloaded from this link: http://zone.ni.com/devzone/cda/epd/p/id/470
Also, consider searching through altenbach's posts for '3D'. He has provided excellent information on different 3D interpolation methods, and if I recall has even uploaded a library of his own interpolation functions.
***EDIT: Wait a little longer... thinking about this again... ***
Message 3 of 34
(37,014 Views)
OK, this is better. My first response went down a rabbit trail of unnecessary resampling... Keep in mind that once you calculate the 3D coefficients, it is possible to resample in order to interpolate or extrapolate, but it's not necessary for me to include in this simple example. Sorry for the schizophrenic responses:
19787i031DF35E1B0E46B1
Message 4 of 34
(37,009 Views)
Why not: just for kicks, here was my original example with the extra resampling bit:
Message 5 of 34
(37,004 Views)
If you have mathscript, you can use the griddata function.
Message 6 of 34
(36,997 Views)
Looking at your data, it is well quantized to a grid if integers with a spacing of 1 and perfectly arranged in the 1D arrays.
In this particular case, you can do as follows:
If the x and y ramps have noninteger increments, you need to remap a little bit. 😉
Message 7 of 34
(36,988 Views)
I tried to generate a 3D plot using the method described here, but I am running into to some problem with the plotting. You can see from my code (file "surface plot" and sample data) attached that I get an unexpected plane connecting the start and end points on the surface plot. Ideally, only the curved surface should be present. It would be great if any of you have any clue. Please let me know if you need more information. Thanks for the help in advance.
Message 8 of 34
(36,402 Views)
Here're additional files you'll need.
Message 9 of 34
(36,401 Views)
No, you are not! Your X axis values are a sawtooth instead of a linear ramp. There are two ways to graph a 3D surface. In your case, your z data is a 2D array, thus your x and y arrays need to correspond to the linear ramps in the x and y direction. Disconnect the x and y vector temporarily to see the real 2D data.
(You also have horrible race conditions, for example in "Table Gen.vi" you are writing to and reading from a global variable and there is no telling what happens first, but the outcome critically depends on it.)
Message 10 of 34
(36,392 Views)
