How to generate the zero packet on the Bulk-OUT pipe by NI-VISA?
I can generate the Bulk-OUT "*IDN?"on this USB RAW Class device by using write. But, how to generate this zero packet(Short packet) on the Bulk-OUT pipe? YY
Message 1 of 10
(4,817 Views)
Have you tried a normal Bulk out transfer with an empty string as an input?  Seems the logical choice.
Shane
Message 2 of 10
(4,790 Views)
I tried, but failed.
Message 3 of 10
(4,756 Views)
Failed?
Error message? Just no functionality? What?
Shane.
Message 4 of 10
(4,748 Views)
no action, no error.
Message 5 of 10
(4,745 Views)
I add write "" to this device.
But, no effect. no error.
Message 6 of 10
(4,686 Views)
What program did you use to show the USB comms?
There is a single difference between the two transfers in the iomage below.  The T on the left of the "number of Bytes" is different but I don't know what that means.  YOu should check the software you used to find out what this means.
I would post a Bug report that VISA is ignoring zero-byte transfers.
Shane.
Message 7 of 10
(4,674 Views)
It'd be helpful to see USB port sniffer captures from successfully sending a zero packet transfer with your program, and from unsuccessfully sending this packet with VISA.
Justin E
National Instruments R&D
Message 8 of 10
(4,637 Views)
Successfully
the difference with unsuccessfully is the red part.
even, I try to write an "" nothing happened.
no warning, nothing happened.
Message 9 of 10
(4,626 Views)
Hi Shane,
  Do you get any response from Ni?
YY
Message 10 of 10
(4,592 Views)
