How to fire an event from LabVIEW DLL to be handled in VC++ program
I want to pragrammatically fire an event in a VI in a LabVIEW-generated DLL, so that the event can be handled by a VC++ program that calls the LaVIEW-generated DLL.
I will appreciate it if someone solve my problem at the earliest.
Thanks and regards!
Javed
(2,785 Views)
Since this is a volunteer board for a large part your hope to solve your problem at the earliest is more or less irrelevant since nobody owes you anything here.
As to your problem it sounds a lot like a roundabout way of doing business. The most easy solution would be probably to let your C program register a Windows API event and give the handle to your LabVIEW VI as a pointer sized integer, then whenever your VI wants to fire that event it calls the according SetEvent() Windows API function passing it that handle. In your C program you have to wait on that event of course probably in a spawned thread.
Rolf Kalbermatter  My Blog
(2,772 Views)
Thanks for your prompt response. Of course! You are right. No one owes me to reply to me at the earliest. It was just a request.
Back to the technical side, can you please send me an example how to register a Windows API event and pass its handle to a LabVIEW program which may fire the event which can be handled in a VC++ program?
Can we make an ActiveX of a VI and fire the event that can be handled in other ActiveX-supporting languages?
Javed
(2,766 Views)
Look on MSDN for the APIs CreateEvent(), SetEvent(), CloseHandle() and related functions. I'm sorry but I don't have an example handy nor the time to create one.
(2,760 Views)
