03-09-2015 12:23 PM
Hi guys
I want control the push type solenoid for x-ray pulsing. I don't have any idea how to interface the solenoid with Labview. The solenoid does not have a serial port it just have two power cable. Can you please help in proving general view how can control using DAQ board. I will appreciate your review and will helpful for me to buy the USB DAQ board. Thanks
Parag
03-09-2015 12:32 PM - edited 03-09-2015 12:32 PM
Without knowing the specifics of the solenoid that you are trying to control, I can't give specific answers, but in general you can't drive a solenoid directly from a DAQ card output. The current, voltage, or (more likely) both, will be out of spec for the DAQ board. You will need some sort of signal conditioning between the DAQ and the solenoid. Sometimes the solenoid vendor will make these boards themselves, sometimes you will need to find one on your own, but again the vendor should be able to help.
Mike...
03-09-2015 12:59 PM
Thank you for your reply.
Here are some specification about the product . What are specification specification for DAQ.
03-09-2015 01:14 PM
