04-23-2009 10:50 PM
Dear all i have two independent application running on same PC. One a C program & a Labview application.
C program will pass some parameters to Labview application and waits for responce back from Labview.
Labview should wait for data from C Program and when it gets that, it should process it and should return it back to C program....
How a program can be made in labview to receive a data form Other appliaction
I am using Labview 7.1.
04-23-2009 11:01 PM
04-23-2009 11:37 PM
This kind of communication works the best when the LabVIEW code is compiled into a DLL.
In C you could call the DLL and the DLL would return the calculated values.
Ton
04-24-2009 04:38 AM
