How do we link multiple stop buttons to make one master stop button?
I am building a program that has multiple loops running simultaneously. How do I create a master stop button/link the multiple stop buttons to one? Right now I have 14 different stop buttons and would like to control them all with one main stop button, that way I won't have to hard stop the program, and for when we compile the program into a stand alone running program, the user will be able to have a master stop button available? Any help would be appreciated. Are there any available tutorials?
Message 1 of 23
(11,334 Views)
Creating local variable of the boolean should solve your issue.
Message Edited by Andy C. on 03-17-2010 12:01 PM
Andy Chang
Message 2 of 23
(11,331 Views)
You can replace all of the various stop buttons and use notifiers. When the user stops the application your master stop would fire a notification and all of the listeners woudl be notified they need to stop.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 23
(11,326 Views)
You can use a local variable to do that, but remember, use local only if you have to.  For the switch, remember to change the mechanical action to switch until released.
Yik
Message 4 of 23
(11,324 Views)
You're better off using a notifier, as Mark suggested.  You are guaranteed not to have race conditions.  You can stop as many loops as you need to.  And, if you name the notifier, you can access it in subVIs too, which can come in very useful.
It looks like this.
This is a more flexible and reliable solution than a local variable.  I'd recommend you do it this way.
Message 5 of 23
(11,303 Views)
As a modification of Diane's approach, I like to wire the error out from the Wait on Notification to the Stop terminal in the while loop, and move the release notifier so that it executes after the master loop stops.  Once the notifier is released, any function that is waiting on that notifier returns an error, causing the loop to stop.  This leaves you free to use the notifier data for something else.
Message 6 of 23
(11,278 Views)
Diane, I have very little Labview experience, could you explain how the notifier works exactly?
Message 7 of 23
(11,230 Views)
Start with the LabVIEW help.  The folks who wrote the help files do a pretty good job of explaining things.  Read the help files for all of the notifier functions, then post back if you have specific questions and I'll do my best to answer them.  Also look at the notifier examples that ship with LabVIEW.
d
Message 8 of 23
(11,211 Views)
Does using the "Wait on Nofication" function here require similar (or even coupled) timing of the two loops?  If one were to use "Get Notifier Status" this would remove this limitation, correct?
Thanks!
Message 9 of 23
(10,028 Views)
Not quite sure what you're asking here.  The two loops run completely independently.  Get Notifier Status returns the most recent message immediately, even if has already been seen.  Wait on Notification waits for a message that that particular node has not yet seen.  It has nothing to do with the timing.
Message 10 of 23
(10,024 Views)
