10-26-2006 06:22 PM
10-27-2006 03:06 PM
Sounds like you're trying to bind a shared variable on your machine to one on the network. You can browse the network to choose what you'd like to bind to as follows:
In the shared variable properties dialog:
1. place a check in the "Bind to Source" checkbox
2. click the Browse button in that section
3. from the Network-Published Source drop-down box, choose Network Items
You should now see the network available to your machine, and you can expand the tree to expose items to bind to.
I hope this helps!
Best Regards,
JLS
10-27-2006 03:11 PM
Thanks for the reply. I realize I left out a key word in my problem description: I need to do this programatically.
NI suggested that I make remote VI server calls to the appropriate DSC Engine Control VIs, but I was hoping for something a bit more elegant - clearly, we can browse machines and shared variables from configuration panels in LabVIEW, and I want to be able to do the same from a VI.
10-30-2006 01:55 PM
10-30-2006 01:58 PM
10-31-2006 11:37 AM
No problem, and sorry I didn't have a more elegant solution for you!
This is DEFINITELY worth of a product suggestion - and that's one of the only ways customers in general have direct access to R&D (those requests are handled directly by R&D and are taken very seriously - every request is read and evaluated).
Thank you,
Best Regards,
JLS
