Get array index by mouse click
Hi ,It is my first post,and please excuse me for my bad english.
My problem is: I want to Get the index array by mouse-click.With Array Property node IndexValue in read mode i can t to read the right index.I try to find a answer in this forum but i dont find a specific thread. Thanks a lot.
(13,030 Views)
If you do a search with "array index mouse" you will find this answer:
https://forums.ni.com/t5/Example-Code/How-To-Return-the-Index-of-a-Mouse-Select-Array-Element/ta-p/3...
(13,022 Views)
(12,989 Views)
Ty at all guys!i have doneSmiley Wink
(12,959 Views)
If your need for the index is only to get the value of cell that was clicked on,
that can be done using Property Node ArrElem.
Omar
(12,949 Views)
Use the MGI Library: https://www.ni.com/en/support/downloads/tools-network/download.reusable-vi-library-for-labview.html
MGI Position to Array Index
This uses VI Scripting, but Master Bounds Rect Property available in Run-Time Engine: https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/properties-and-methods/vi-server/generic/g...
(9,158 Views)
This vi Very Helpful
Thank for Sharing..
(6,373 Views)
