Get Computer Name
I think there was a VI
'Get computer name'
somewhere in the GToolbox (or former LVutil).
I cannot find it - any hints?
I need the name of the computer the program works on because it
communicates with another application via TCP/IP and I would like to set
the standard application adress as the local PC.
Urs Bögli
Message 1 of 12
(23,701 Views)
Hello Urs,
An easy way is to use the "string to IP" wired to the "IP to string" VI (TCP palette). The IP to string function has a boolean input where you can define if you want to see the IP address or the machine name of the PC.
Luca
Luca
Message 2 of 12
(23,701 Views)
hello
See the attached vi
Hope it helps.
Alipio
"Qod natura non dat, Salmantica non praestat"
Message 3 of 12
(23,703 Views)
Luca,
that's fine, an easy solution but hard to find !
Attached is my VI now.
Urs
Luca P. schrieb:
>Hello Urs,
>of the PC.
>Regards,
>Luca
Message 4 of 12
(23,703 Views)
Alipio,
thanks for this solution. I think its disadvantge is the OS dependance.
Some target PCs are Win98, some Win2000.
The other solution mentioned seems to be independent of the platform and
is very easy to implement!
see other news
Urs
alipio schrieb:
>hello
>See the attached vi
>Hope it helps.
>Alipio
Message 5 of 12
(23,703 Views)
This one worked nice!
Message 6 of 12
(18,561 Views)
You could always use the system exec to run the command
IPCONFIG /ALL
Then parse the text for the Host Name
That would eliminate any Windows version poblems.
=== Engineer Ambiguously ===
Message 7 of 12
(18,541 Views)
More than ten years later, Luca's solution is still very easy and has no Windows version problems. It looks like this :
Message 8 of 12
(18,521 Views)
If you want more than just the computer name, you can use something like this.
Message 9 of 12
(18,485 Views)
But not such a good solution on Windows Server OS:
https://lavag.org/topic/19322-get-host-name-performance-issue/
-John
Certified LabVIEW Architect
Message 10 of 12
(17,034 Views)
