Gaussian peak Fit FWHM
Hi
I am using the Gaussian Peak Fit Vi and I want to calculate the FWHM of the fitted curve. What is the best way to do this. Thanks
(5,138 Views)
Hi Zepp
I'm not too familiar with the Gaussian function, however after some quick research I've seen that the:
FWHM = 2 * (sqrt (2*ln 2)) * C
Where I believe C is the centre.
To build this you can either use a math script node or build it using the correct function blocks. I've attached a VI and VI snippet that uses both of these methods. I haven’t wired up the inputs of the Gaussian Function as I am quite unfamiliar with it.
Let me know if this is what you were looking for.
Many thanks.
Dan
Daniel Harryman MEng
CLA, CPI
(5,102 Views)
C here is the standard deviation
(4,325 Views)
Almost correct: C is not the center, it is standard deviation.
PS. for single variable, single line formulas it is better to use expression node.
(4,312 Views)
If you search for FWHM Gaussian, you can find that the Full Width at Half Maximum (which "answer analysis" should tell you will be related to the Standard Deviation, usually expressed as a lower-case sigma, σ, is
(4,310 Views)
Hi Alexander,
I appreciate the feedback. Silly mistake on my part.  Kind of makes me want to go back and check a few of my older forum posts and see if I'm any wiser now or just older haha.
Daniel
Daniel Harryman
Certified LabVIEW Devloper
Electronics Engineer
ISIS Neutron & Muon Source
Accelerator Diagnostics Development
Science & Technology Facilities Council
Rutherford Appleton Laboratory
CLA, CPI
(4,293 Views)
