09-10-2013 03:54 PM
I have been working with a couple of versions of a main VI. The original VI was given to me so that I could add additional functionalities to it. I had been designing the front panel of the latest version of the VI on a Dell laptop running Windows 7 and LabView 2011 SP1 using a monitor with a resolution of 1920x1080. My booleans, numerics, and plots on the front panel had always stayed in place after saving, closing, and reopening the VI. Once in the field, I connected my laptop to a cRIO9073 and used my laptop screen with a resolution of 1366x768 to operate the VI. I made some changes to the VI, saved it, and reopened it. This time I noticed that the front panel objects had become overlapped, resized, and generally rearranged. I tried fixing the objects but I noticed that they reverted back to the incorrect positions after saving and reopening the VI. I was successful in keeping the objects in position a couple of times, but when I would open the VI at a later time, the objects were again rearranged. This is happening on both my monitor and laptop screen. The original version of the VI, however, does not behave this way and I have opened it on both my monitor and laptop screen. In this version, the front panel objects always stay in place. Both VI's have the same window size properties. Could I have corrupted the latest version of my VI somehow? Below are screenshots of the front panels of both VI's.
09-10-2013 04:17 PM
Hello Miguel,
You've likely already checked this, but do you have a non-default setting for the Window Position VI Property. I've seen similar behavior in VIs set to Maximize on different screen sizes.
09-10-2013 04:42 PM
Hello Tom,
In the VI Properties under Window Size, my Minimum Panel Size is Width = 0, Height = 0. The "Maintain proportions of window..." and "Scale all objects..." boxes are not checked. Under Window Run-Time Position, I have the position set to Unchanged. Is this what you mean?
Miguel M.
09-10-2013 05:09 PM
Yes, I was referring to the Position property.
That is quite odd- could you provide a screen capture of what the updated UI is supposed to look like? It appears a number of things have changed.
It's possible that something is awry with the tab control or the front panel as a whole, however it's more likely that a setting has changed that's not obvious.
If the front panel is copied and pasted into a new VI and saved & re-opened, do you see the same rearrangement?
09-12-2013 02:16 PM
Tom,
Below is a picture of the updated front panel. I have noticed, now, that my front panel objects rearrange only when I open the VI on my laptop after designing on my monitor. When I go back to my monitor they are still scrambled. I copied the front panel to a new VI and opened this new VI on both my monitor and laptop. There was no rearrangement. Could I have done something programmatically to my front panel objects. I don't think I have.
09-19-2013 09:49 PM
Hi Miguel,
It is possible to programmatically set or change the position of front panel objects. (for example: http://digital.ni.com/public.nsf/allkb/4D0DA06B43195B3F862572F3000AF2D3?OpenDocument) However, if you haven’t intentionally done that, it seems unlikely that it is the problem.
Have you tried copying the entire block diagram in to a new VI to see if the problem persists? While it is unlikely, you are right that it is possible for VIs to become corrupted. I’ve never heard of a situation like this except in the situation where the settings Tom had you check have been changed. Here is some information about those settings:
http://digital.ni.com/public.nsf/allkb/7567EF257B9CFDF986256F630073228F?OpenDocument
Since there was no rearrangement when you copied the front panel to a new VI, you might try copying the block diagram a little bit at a time to see if there is some particular part of it that creates the problem somehow.
K. Johnson
09-19-2013 10:04 PM
VI is adjusting itself based on monitor size. This is always the case. Make sure when you create your installer then in VI properties select window size tab as per your requirement.
