Finding FTDI Chip COM Port Numbers
I was seaching for any easy way to obtain the COM port numbers of FTDI Chips to know whether or not to attempt to connect to a device. FTDI Chip has LabVIEW drivers on this page but they only use an ID number (Handle) to communicate with the devices. Here is how to do it for those interested....
Referencing the FTDI Chip manual....
http://www.ftdichip.com/Support/Documents/ProgramGuides/D2XX_Programmer%27s_Guide%28FT_000071%29.pdf
All the functions in the manual call "FTD2XX.DLL" which is installed with the FTDI Chip D2XX driver. A call not included in the LabVIEW drivers is the "FT_GetComPortNumber" function which uses a the ID number (Handle) to obtain a COM port number.
Attatched is the edited FTDI Chip drivers with two new VIs:
1) FT_Get_Com_Port_Number.vi
2) Get COM Port Number Demo.vi
Block diagrams:
1)
2)
Message 1 of 18
(14,540 Views)
I remember finding the COM-ports with Visa Find Resources...
to know what filter you want you should use: devcon microsoft
It works this way to.... (from the old thread 🙂 )    , I have two ftdi's connected to my machine and it shows me the 1st one when I use ASRL as filter!
Good luck!
Message 2 of 18
(14,507 Views)
Good luck!
Why not just autoindex the array?  Then you do not need to wire up the N or use Array Index.  That's what my code for this setup does.
Message 3 of 18
(14,488 Views)
I really dislike using the D2XX driver since the ports don't show has RS232. It forces you to only use ftdi converters and you can't use the normal LabVIEW serial functions.
Message 4 of 18
(14,466 Views)
I believe the issue with this method is that you can't get any information from the ASRL resource to denote that it is an FTDI Chip, or whatever manufacturer for that matter. So say you have 10 ASRL devices connnected, and only one of them is an FTDI Chip, using NI functions you would have to query each resource and hope for a reponse.
Message 5 of 18
(14,437 Views)
 I agree, but unfortunately there doesn't seem like there is a better way to do it...
Message 6 of 18
(14,431 Views)
Why would you even care if its ftdi or not? It's all transparent when emulating a serial port. Generally, what is important is the actual instrument connected at the other end. Knowing a certain port is using an ftdi converter will not tell you the actual instrument.
Message 7 of 18
(14,429 Views)
Serial instrument drivers tend to have long timeouts when initializing resources with an invalid resource. This can be eliminated by understanding what serial interfaces the resources use and only attempting to communicate with those. Plus, querying invalid resources could result in unwanted communication errors.
Message 8 of 18
(14,422 Views)
Timeouts are as long as you make them. You know how to change them, don't you? You would still have to query each port to determine which instrument is connected. The VISA function returns valid ports. Nothing returns valid instruments. You've probably never seen instruments connected in a random fashion after several have been removed for calibration or seen an instrument vendor change its chipset set when an internal converter is used. Sorry, but let's agree to disagree and leave it at that.
Message 9 of 18
(14,407 Views)
Timeouts are specific to the device connected. If the device needs 2 seconds to respond to an identification/initialization query then it needs an even longer timeout. When attempting to scan for connected devices, waiting for 3 seconds for each device is a waste of time when its is not going to respond.
Of course, I would never use this functinoality on a piece of hardware I didn't develop. But as the hardware designer I know that it will always be an FTDI Chip.
I've stated my problem clearly and provided a solution for others to use; if you don't have anything useful to say then please don't clutter the thread.
Message 10 of 18
(14,402 Views)
