FTP Timeout and FTP protocol question
I'm unable to open an FTP connection in LabVIEW, I can in a browser.  I drilled down and found TCP Read xTP Reply.vi  is the issue.
It's using ^[0-9][0-9][0-9] [^\r\n]*\r\n as the pattern on a match pattern.
My FTP's reply is:
220-FTP Server
220-*** Files stored here are not backed up ***
220-*** Please move any important files to  ***
220 *** alternate storage.            ***
The dash is the problem.  I'm trying to find out if the dash is actually violating the FTP protocol on replys so I can tell IT they messed up!  😛  I mean, ask them nicely to change it.  Or if the VI should be modified because there mite not always be a space.
Message 1 of 14
(4,467 Views)
Hey ,
I'm not really sure what your question is with regards to LabVIEW.
It seems you are talking about FTP protocol with references to syntax and using a hyphen? "-"?
In the following link, it talks about using a hyphen in the reply of FTP protocol:
https://www.w3.org/Protocols/rfc959/4_FileTransfer.html
Specifically,
the format for multi-line replies is that the first line
         will begin with the exact required reply code, followed
         immediately by a Hyphen, "-" (also known as Minus), followed by
         text.  The last line will begin with the same code, followed
         immediately by Space <SP>, optionally some text, and the Telnet
         end-of-line code.
            For example:
                                123-First line
                                Second line
                                  234 A line beginning with numbers
                                123 The last line"
 Let me know if this addresses the issue you were having.
Message 2 of 14
(4,418 Views)
LabVIEW won't open an FTP site that replies with multiple lines then.  The pattern anchors the 3 digit reply code to the start of the string and there is no space.
Message 3 of 14
(4,412 Views)
Hey,
To get a better idea of what you're working with. Are you using the FTP functions built into LabVIEW?
FTP VIs
http://zone.ni.com/reference/en-XX/help/371361K-01/lvcomm/ftp_vis/
Also would you be able to make a snippit of your code so that I could determine what the issue is?
Use VI Snippet to Store and Share Reusable Code Sections
http://www.ni.com/tutorial/9330/en/
Message 4 of 14
(4,400 Views)
Built in FTP VI's.  It is getting stuck in the FTP open.
Message 5 of 14
(4,395 Views)
I have a couple ideas about that.
Firstly, your syntax should probably look something like the following:
post-15324-0-89154900-1369910270_thumb.j
Also, I suggest testing your VI with constants to make sure that your syntax is correct. Try finding a simple example that works and then building on that.
Message 6 of 14
(4,379 Views)
You have a reset from somewhere in front, but the only input that matters is the IP.  The IP is right because I'm getting a reply.  I never get out of the FTP open.  I'm pretty sure if you aim your VI at any FTP server with a multi-line response it will fail.
Message 7 of 14
(4,366 Views)
How are you getting a reply back if you hang in the FTP open?
Have you tested this reading back a single line? Is that working exactly as expected?
What does a "fail" mean for multi-line responses?
It appears that the standard FTP protocol uses "-" (minus) when doing multi-line responses, so I'm still a bit confused on what behavior you are seeing.
Spencer R | NI
Message 8 of 14
(4,341 Views)
I have now also put a filezilla FTP server up locally.  I can open it in my browser. (ftp://192.168.44.53/)
My code also opens that FTP site and gets a directory list, as designed.
When I change the IP to point at the company FTP that responds with multiple lines it gets error 56
Open the FTP Open Session.vi
Drill down to: FTP Get Command Reply.vi -> TCP Read xTP Reply.vi (Snippet attached)
You can see a match pattern with ^[0-9][0-9][0-9] [^\r\n]*\r\n   It's looking at a shift register with the reply string.  I probed it:
220-FTP Server
As I said in the first post, that pattern will NEVER find the reply because it must be ###<SPACE> and a multi line replies ###<DASH> and it's anchored to the start of the offset 0.
Also attached a match pattern wired up to show it.
Message 9 of 14
(4,327 Views)
Is it possible to receive the multiple line response and convert it to a single line so that FTP Open will not hang?
Adam
Message 10 of 14
(4,301 Views)
