02-14-2013 11:22 PM
Good Morning,
I want to perform grayscale morphological transformation on images saved in a folder. When I tried to execute the program I encountered the following error.
Error -1074396080 occurred at IMAQ Extract Single Color Plane.
Possible reason(s):
IMAQ Vision: Invalid image type.
Can anybody help me what is the cause of the error.
Thank you for your help.
02-14-2013 11:33 PM
2011 compatible VI please
02-14-2013 11:52 PM
Thank you for your response.
I have attached the 2011 version of the program.
02-15-2013 07:08 AM
Your subVI "DilateErode_Edge2012" is missing. Obviously, this subVI loads the image, so an fundamental part for support is not shown....
PS: Maybe you only have to connect the image(space) you created to the missing subVI....
Norbert
02-15-2013 07:19 AM
I have attached the missing subvi in 2011 version
02-15-2013 07:29 AM
Hm, there are some weird points in your top-level VI. Nevertheless: How does the "Edges" output from DilateErode_Edge VI look like? Is it a proper image?
Norbert
02-15-2013 07:38 AM
dont have LV opener right now but the error is stating that the type of the image is incorrect. you should have a RGB (or HSL) 32 bit original image and place it into a 8bit image for the color plane, are you doing this?
02-15-2013 07:48 AM
One side note: Using IMAQdx for my laptop webcam works correctly when executing the DilateErode_Edge VI only.
So i guess the camera you are using is creating invalid images (empty?).
Norbert
02-15-2013 07:50 AM - edited 02-15-2013 07:57 AM
Please check the link.I am using the program given in that link as part of my processing.instead of acquiring image I want to give the input images that are saved in a folder ,process them using the "dilate erode " technique and save the obtained output image to another folder.
02-15-2013 07:55 AM
That is exactly your subVI DilateErode_Edge....and it runs properly on my system. Does it work on your system?
Norbert
