09-23-2009 06:29 AM
Need help to implement the graceful exit subroutine for my application.
High level architecture of the application is attached here.
"A" is a central controlling entity invokes (Dynamic Call) the AXx (yellow oval). AXx further invokes AXXx (blue oval) and so on (Whenever required, it's not shown in figure). These represents the application level/ GUI in architecture.
D1 through D7(green rectangle) are LabVIEW VIs, which deals with Device Drivers (MAX)/ DLLs/ Low level device drivers etc. D1 - D7 are invoked by AXx/AXXx and don't communicate with "A". Data transfer between D1- D7 and AXx is achieved using various means like Queues, LV2Gs etc. The synchronization between various layers is achieved using Events.
When it is required to Exit the application, I wish that the VIs should execute a proper Exit subroutine (Closing the references/ releasing memories of Hardware devices/ closing ports etc. Of course this is for the particular vis). The stop process is initiated from "A" only. As D1- D7 are not controlled by "A", finding difficulty while implementing the Application exit subroutine.
Can any one help me in identifying/ implementing such methodology?
Notes: Almost all the VIs in application are employing Hybrid design pattern (Combination of State machine and Event architecture).
I don't want to Exit the application directly from A.....Before the application could Exit, need to ensure few things which needs graceful shutdown/ exit subroutine to be executed.
09-23-2009 07:01 AM - edited 09-23-2009 07:01 AM
I have also an architecture with dynamic VIs. You need to define an event "Stop" for each of the VIs. Also you need to define an "Ended" event which will be thrown when the shutdown task of the VI is finished.
In your example A would send "Stop" to AXx. AXx would send "Stop" to D1 .. D7. D1 .. D7 will answer with "Ended". When all "Ended" events have received AXx then AXx would send "Ended" to A. A will then stop executing and leaving the application.
09-24-2009 06:13 AM
Hi Waldemar,
Thanks for the reply.
Whatever procedure you explained seems to be OK for normal scenarios. But just consider the scenario, where in Axn has encountered an error and is not able to communicate with D1- D7. "A" is responsible for health monitoring of Axn level modules. As soon as "A" come to know that error in Axn, I want all the Vis to be stopped. Since Axn is already erroneous (stopped)....it won't be able to communicate with D1-D7.
How do I proceed in this scenario?
09-25-2009 05:20 AM
You have two solutions:
1: Change the error handling in Axn so that it wont stop in case of an error. It will act on "Stop" and "Ended" but ignore all other commands. The worst case here is that you will lose the references to the user defined events or queues. But I never got that on queues. I do not use user defined events in this scenarios.
2: You have to create direct channels from A to D1-D7. In this case you need to collect the references from Axn for all the loaded VIs. Althoug you need to give information to D1-D7 where they will send there "Ended" respond.
We implement the first solution. All the VIs are running until they get an explicit "Stop" during application shutdown. In the case of an unrecoverable error they will change their state to "erronous" but respond to the "Stop" .
