Exe not communicating in other PC
Hello
I have created a VI which is communicating over opc to siemens plc,and is working fine.
now when i created an exe application and used it in another pc which has labview,it doesnt communicate.
perhaps i am missing something very basic,kindly guide me the proper way for it.
regards
Parmod Takkar
Message 1 of 15
(3,587 Views)
Did you install the necessary LV Runtime and drivers for the components of your application? If you're using OPC, are you using the DSC module? Have you installed/activated an appropriate DSC run-time license?
(blog)
Message 2 of 15
(3,582 Views)
What error messages are you getting?
In general, one place to looking is for setup parameters that you have hardwired.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 15
(3,578 Views)
As the other PC has same component installed as the one in which application is developed,and it is woking in that PC,so i assumed nothing is required to be installed in other PC.if these are required to be installed,please let me know the procedure for it.
Message 4 of 15
(3,573 Views)
@mike porter...
I dont get any error message but the values of bound variables is not changing when i m running the exe.but when i run the exe in the same pc it works fine.
Regards
Message 5 of 15
(3,569 Views)
It would also be helpful to see your code. It early in the morning here, I haven't had a cup of coffee yet so my mind reading is a bit weak at the moment.
Mike...
LabVIEW Champion
Message 6 of 15
(3,562 Views)
@mikeporter
Here is the code,its very basic ,the problem here  is communication.
enjoy your coffee,will wait for the reply
Regards
Message 7 of 15
(3,547 Views)
I also tried creating installer but the same thing happenned.it workd in the same pc but when i try it on other one,no tag communicates.
Regards
Ptakkar
Message 8 of 15
(3,503 Views)
Others with even more experience can check me here but, Building your exe to user\Desktop\ generally does not port well.
Set the destination to C:\<Company>\MyApp and see if that helps.
And in your installer remember to add a short-cut on the desktop
"Should be" isn't "Is" -Jay
Message 9 of 15
(3,495 Views)
even tried that,made the application in C.nut it didn't help,still at the same ground 😞
Spoiler
Message 10 of 15
(3,463 Views)
