Good morning
It sounds like you have an interesting issue here. A couple of questions though. with Vision are you using the IMAQdx drivers as these will only work on versions post 8.0? If not can you not just save your labview VIs into a previous version eg. 7 and then your client to access it.
If this is not the case or if you can explain your complications a little more clearly then I would be happy to build these exe files for you. What sort of size are the files in question. Can you post them up here then I can pull them off the forum or are they more substantial and would need an FTP site?
best regards
Graham Green
Sr. Product Marketing Manager
National instruments
