07-19-2007 01:59 PM
07-19-2007 02:37 PM
07-20-2007 07:51 AM
07-20-2007 08:06 AM
07-20-2007 08:30 AM
07-20-2007 08:40 AM
07-20-2007 09:26 AM
07-20-2007 10:11 AM
07-20-2007 11:13 PM
@petrem wrote:
I think in this case, it is a reasonable approach because the two nested events are "mouse down" and "mouse up" over a single control. These two events must follow each other with no other event possible in between (I don't have a keyboard - only a touch screen, so no other user input).
07-21-2007 07:54 AM
@petrem wrote:
After searching on the forums a little more, I decided to try a nested event structure.
Noooo!!!! Never nest event structures! Your code is overly complicated. It is NOT "simple coding" (your words)! 😄
All you need is three very simple event cases, each containing nearly no code:
See for yourself in the attached draft (LabVIEW 8.2) ! 🙂
Let me know if anything is not clear.
