Errror 65700, cRIO in Hybrid Mode LV14f1 and NI RIO 14.0.1
same Problem like here: http://forums.ni.com/t5/LabVIEW/cRIO-Hybrid-Mode-Error-65700-Randomly/m-p/3079081
- LV14f1
- cRIO-9076
- NI RIO 14.0.1
- VI in hybrid Mode
- NI 9213
- NI 9234
- NI 9401
- NI 9481
If i download the compiled FPGA Bitfile, then select "Deploy All" it works fine - but only one(!?) time. When VI is stoped and restarted then i get the "Error 65700".
(3,321 Views)
finally this is the solution -> according to this: http://zone.ni.com/reference/en-XX/help/373197B-01/cserieshelp/scan_interface_for_modules_rt/
"...Tip  There is a short delay between the time when the Open FPGA VI Reference function finishes running and the time when user-defined variables and modules under the chassis item return valid data. If you have user-defined variables in your VI, run the Open FPGA VI Reference function and then read the variables in a loop until they return no errors."
thanks to:
Nina Mangold
Applications Engineering
(3,302 Views)
