04-18-2012 03:00 AM
Hi there,
I use the USB-LIN for a simulation for LIN bus. We had the LDF file of version 2.0 before but now we get a new LDF file which is in version 2.1.
We used
to read the LDF file but it seems that the kit doesn't work any more with the LDF version 2.1.
It there a workaround for the LDF file with version 2.1.
Thx,
Wilbur
04-20-2012 04:21 AM
The NI USB-LIN was created to work with the version 1.3 network standard. However, version 2.0 and 2.1 are backwards compatible, so the NI USB-LIN will work with these networks as well.
there is currently not a plan to update it for LIN 2.1.
Note: The new features introduced in version 2.0 and 2.1 network standards will not be natively supported with the NI USB-LIN.
LIN Version 1.3, 2.0, and 2.1 Comparison
| Feature | Supported by NI USB-LIN |
LIN 1.3 |
Yes |
LIN 2.0 |
Yes* |
| Enhanced checksum | Yes |
| Off the shelf slave node concept | Yes* |
| NCF format | Yes* |
| Diagnostics and slave node configuration | Yes* |
| Byte arrays | Yes |
LIN 2.1 |
Yes* |
| New slave node configuration services | Yes* |
| Slave diagnostics class I-III | Yes* |
| Functional addressing | Yes* |
| Resolution table |
Yes* |
04-20-2012 07:59 AM
I do believe that the hardware still support the new protocoll. But my question was whether the LDF file in v2.1 can be accepted when I use the "LDF Database Open.vi".
04-24-2012 09:46 AM
you can also try to install the new NI-CAN driver, which support the LIN-Bus.
NI-CAN 2.7.3:
http://joule.ni.com/nidu/cds/view/p/id/2646/lang/en
