Error -88302 occurred at DAQmx Create Channel (AI-Voltage-Basic).vi:1
Thanks for your kindly help, The problem is solved. I uninstall the LV and DAQmx, reinstall Both of them, it is ok now.
Message 11 of 16
(2,589 Views)
I had the same error and fixed it by uninstalling and reinstalling DAQmx.
Message 12 of 16
(2,450 Views)
This document will be able to read analog signals from a DAQ USB6008, this program is useful to read the value recorded by a temperature sensor, the value of voltage or analog signal
Message 13 of 16
(2,366 Views)
I recently encoumtered the following error: errror-2147220719 DAQmx Create Channel(AI-VoltageBasic).vi:170001 May you please assist.
Message 14 of 16
(1,833 Views)
I recently encountered the following error: errror-2147220719 DAQmx Create Channel(AI-Voltage Basic).vi:170001 May you please assist.
Message 15 of 16
(1,833 Views)
Since this forum post is very old and is marked as answered already, you would be best helped by asking a new question on the Multifunction DAQ message board. You can find that forum at the following link:
Multifunction DAQ
https://forums.ni.com/t5/Multifunction-DAQ/bd-p/250
Alex C.
Applications Engineering
Message 16 of 16
(1,820 Views)
