08-04-2010 12:42 PM
Hello All!
As the subject says I'm getting this error from time to time. VI will run just fine and after couple of hours or so, I'm getting error message.
My systen is:
Windows XP Professional
Version 2002
SP2
Data Source Driver:
SQL Server Version 2000.85.1132.00
File:
SQLSRV32.DDL
08-05-2010 05:08 PM
Are you running any other programs that are accessing the SQL database? Is LabVIEW accessing any other Databases with the Data connectivity toolkit?
08-06-2010 06:40 AM
Aside from my application there's other people accessing the database using NWA (Northwest Analytical).. and no, we just have one database.
08-09-2010 09:31 AM
It seems that an error is actually being thrown by the database and not LabVIEW. Error -2147467259 is an unidentified LabVIEW error code that often relates to a third party object.
Furthermore, you seem to be getting fatal error 824, which is a database error. This could mean that some data is corrupt in the table you are trying to access.
I would recommend running some diagnostics on the database because this does not seem to be a problem with the LabVIEW code itself.
08-09-2010 09:39 AM
When I talk to our IT, he mentioned something about memory issue in the server side when I'm sending my query. Also found out that we are using virtual server, but then not sure if it has anything to do with this issue.
Thanks!
