Driver for HP8753E?
I see LV drivers for the HP8753A,B,C,D but not E.
Anyone know if this exists? Can I use my A/B/C/D driver with the E?
Thanks!
(3,452 Views)
Hi Jason,
The 8753E can be controlled using any code written for 8753D. So the Existing Drivers will Work. There are certain features of 8753E which however may not be part of the old drivers. For Instance the 8753E is Extremely fast if you turn off the Analyzer display. This feature is missing in 8753D.
Also there are Options available with "E" Which were not available with "D". The "A" and "B" dont compare as close to "E" as "D" does. So Use any driver used for 8753D. If you need to avail of fetaures of E. Code the Functionality.
Good Luck!!
Mache
Good Luck!
Mache
(3,452 Views)
The 8753E Driver can be downloaded from Agilent Website. About 1.5 M. Support LV/LabWindows.
Here is the Link..
http://we.home.agilent.com/cgi-bin/bvpub/agilent/editorial/cp_MiscEditorial.jsp?OID=536913831&NAV_ID=-11916.536881282.03&LANGUAGE_CODE=eng&COUNTRY_CODE=ZZ
Search "8753E" at www.agilent.com Follow the 8753E Link Under "Product and Services" and Go to Library and Select VXI Driver.
Mache
Good Luck!
Mache
(3,452 Views)
