Another question need u all guy help.I currently using K-type thermocoupler for my project using usb 6008.Does the voltage to temperature conversation require in usb 6008 using daqmx 8.5? what is DAQ TEDS function use ? is it help us to convert?
You will need to factor the voltage per degrees C to get to reading in degrees, this is 10mv per degree V for the device mentioned in the post you previously made
