Does Universal Library Extension works for LabVIEW2011?
I just installed LabVIEW2011 and seems that I cannot loaded the VIs in the Universal Library Extension from Measurement Computing Corp. Is this library compatible with LabVIEW2011? Is there anyone also has the same problem? I tried to check the website of the Measurement Computing Corp, but the website is down and I cannnot open it.
Thanks!
(3,358 Views)
Accepted by topic author Xiangshi
I ran into the same problem as you.  The answer from MCC technical support was they don't support LabVIEW 2011.  We found a way to get around it though.  You can install the MCC CD on a computer with LabVIEW 2010 or lower.  Copy all the folders and files pertaining to MCC to your computer with LV2011.  Remember to check
C:\Program Files\National Instruments\Shared
C:\Program Files\National Instruments\LabVIEW 2011\user.lib
C:\Program Files\National Instruments\LabVIEW 2011\vi.lib
C:\Program Files\National Instruments\LabVIEW 2011\resource
I recommand doing a window file search.  Or you can install LabVIEW 2010 or lower.
(3,334 Views)
Thank you very much for your help! It works now with your suggestions 🙂
(3,318 Views)
No problem.  I just had the same problem in less than a week ago, so it is still fresh in my mind
(3,305 Views)
