Display selected column in the output of array
Message 11 of 14
(932 Views)
Thank you for ur replies everyone...............thanks alot
But through this VI. I have to give checkmark for each and every column. Instead i would like to give a single checkmark and all the columns corresponding to that checkmark name should be deleted.
THANKING YOU
Sudhin sudh
Message 12 of 14
(853 Views)
Have you checked my VI(Test2.vi) in last post?
And your first post doesn't ressembles to your current post..
Message 13 of 14
(847 Views)
Thank you for ur reply
Yeah i have checked ur VI
In my first post itself i hav mentioned it. Its a kind of filtering were required columns are shown and remaing columns are not shown.
I was struggling only in the case were for each and every column i have to give a checkmark.
The logic which i require is just with a single checkmark, all the columns with that checkmark name should get deleted.
Eg; If i checkmark Angle ..All the column with angle as heading should be deleted ...Just as a kind of filtering, were i just can see only the required column which i want.
Thanking you
Sudhin sudh
Message 14 of 14
(843 Views)
