12-16-2014 11:31 AM
I am facing a strange issue with database, the data was logged to the databse without any issue until the size of the database was 2GB, just after this size was crossed LabVIEW threw an error saying that the database is corrupted. I am using Microsoft.ACE.OLEDB.12.0 as the database provider. This issue related to size has occured twice and I not sure about the reason behind it. Please suggest a solution for this issue.
Mukunda
12-16-2014 11:36 AM
What Database are you connecting to?
MS SQL ? MySQL?
Where are the database stored ? Local or server?
12-16-2014 12:06 PM
The desktop edition of SQL server (MSDE) has a 2gb limit. If you are on an older operating system with FAT32 file system, i believe there was a 2gb file size limit.
12-16-2014 12:15 PM
12-24-2014 01:16 PM - edited 12-24-2014 01:28 PM
I am using Microsoft access and OLEDB as database engine.
The Operating system is Windows 7 64 bit.
If there is some robustnes issue I am really surprised that it exactly happened at 2GB size for 2 times.
Mukunda
12-24-2014 01:45 PM
It's not a robustness issue, that's a size limit. It'll happen every time your db gets that large.
12-25-2014 09:09 AM
