Darren's Weekly Nugget 08/02/2010
Just in time for NI Week, LabVIEW 2010 has released!  Over the next several weeks, my weekly nuggets will highlight some of my favorite features in LabVIEW 2010.
Cool LabVIEW 2010 Features Part I:  Replace and Insert with Quick Drop
Soon after I released Quick Drop with LabVIEW 8.6, one of the first requests was the ability to do Replace and Insert operations with Quick Drop instead of the palettes.  Well, it took a few releases, but we finally got it:
Replace with Quick Drop
Select one or more diagram objects, press Ctrl-Space to bring up Quick Drop, type a palette object name (or a project item if you have one or more LabVIEW projects open), press Ctrl-P, and all the objects you had selected on the diagram will be replaced with the object name you specified in Quick Drop.  And yes, it does do the replace "correctly" with Compound Arithmetic... 🙂
Select one or more diagram wires, press Ctrl-Space to bring up Quick Drop, type a palette object name (or a project item if you have one or more LabVIEW projects open), press Ctrl-I, and a separate instance of the object you specified in Quick Drop will be inserted on each wire.  I also included special functionality when Ctrl-Shift-I is pressed.  I call this "Smart Insert".  With Smart Insert, a *single instance* of the object name you specify will be inserted on multiple wires.  As an example, if you select a refnum wire and an error wire, press Ctrl-Space, type "Property Node", and press Ctrl-Shift-I, a *single* property node will be inserted on both the error wire and the refnum wire.
Message 1 of 10
(15,326 Views)
Yes!  This was the first comment a colleague made when he first used QD.  Nice work Darren!  (... also like the implementation of Ctrl-Shift for multiple wires)
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
Message 2 of 10
(15,305 Views)
AWESOMENESS!! I bow to thee o' Deity. Smiley Happy
This alone is enough reason to upgrade to LV 2010 Smiley Very Happy
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 3 of 10
(15,085 Views)
I am truly amazed. Smiley Surprised  I was very slow warming up to Quick Drop, but now I'm going full speed ahead with these new and very useful features.
- tbob
Inventor of the WORM Global
Message 4 of 10
(15,050 Views)
I am having a problem with the Insert functionality.
If a wire braches into several paths, and I click on a downstream one and then try to QD Insert a VI, the dropped VI always ends up on the main shared wire instead of the specific branch that I have selected.
Is there any way around this?
Message 5 of 10
(12,981 Views)
As discussed in this thread, Quick Drop Insert doesn't work properly on a selected segment of a forked wire.  I'm looking into ways to fix it.
Message 6 of 10
(12,972 Views)
I would argue that the expected behavior for Ctrl-Space....Select....Ctrl-P for the 1/x function replaced by a Compound Arithmetic should be:
not what it currently is:
This, BTW, is what the "Replace" menu does, so there is no benefit really in using the Ctrl-HyperSpace projection (at least to me).
And similarly for (-x) and x^2.
Message 7 of 10
(10,368 Views)
If desired, you could alter the behavior of the Replace.vi plugin to handle the Reciprocal properly (choose Multiply mode, invert the input, resize for one terminal, adjust position to center the new node).
I've attached a hasty example of what I mean.
Message 8 of 10
(10,355 Views)
Attached is an even better version that eliminates the subVI.
Backup the version of "Replace.vi" that you have at C:\Program Files (x86)\National Instruments\LabVIEW 2013\resource\dialog\QuickDrop\plugins and replace it with this version.
Message 9 of 10
(10,346 Views)
I am not into replacing chunks myself. I'll leave it to the professionals.
BTW, there are a few more potential improvements posted here.
Message 10 of 10
(10,345 Views)
