08-05-2011 02:14 PM
Good Afternoon,
I'm trying to output a constant voltage (from 0 to 5 volts) through a DAQ assistant and running into problems. Here's what I have now
And the error I'm receiving is
As always, Thank you all for your help,
Nicole
08-05-2011 02:52 PM
What type of device are you using? Does it show up in MAX?
08-05-2011 02:54 PM
I'm using a NI 9269, what is MAX?
08-05-2011 03:18 PM - edited 08-05-2011 03:25 PM
I don't use DAQ Assistant but I bet that you can't use two of them with one DAQ. You have to add a channel and configure one DAQ Assistant to output your two signals.
EDIT: NI MAX is the Measurment and Automation Explorer that ships with almost every product and driver. I'd like to point you to a NI website that explains it but there doesn't appear to be one! ![]()
It's in the start menu under National Instruments. OPen it and look in the help.
08-05-2011 03:20 PM
I am using two channels, unfortunately I can't get it to work even with just one channel being used
08-05-2011 03:31 PM
Close LabVIEW, open NI-MAX, double-click 'Devices and Inerfaces', click on your card, go to the test panels tab and verify you have any output.
08-05-2011 03:49 PM - edited 08-05-2011 03:49 PM
Here's what I get on thes test tab
08-05-2011 03:53 PM
Have you tested your device in MAX? What are the results?
08-05-2011 03:55 PM
When I select self test a pop-up appears and says that it passed the self test
08-07-2011 12:31 PM
Have you tried searching the forums for the error number?
This is a common error and you quickly will see that you can't split your analog output between different DAQ assistants.
