Cursors in XY Graph are blinking
The graph at XY graph component should be repainted too often (2 - 3 times in second). The graph doesn't blink, because "Update smoothing" option is on.
But cursors at this graph are repainted every time so they are blinking very strong and customer says it annoys.
Is it possible to avoid this?
Thanx
(2,191 Views)
Hallo Thanx,
one idee which i had, is to use the property nodes of the XY-Graph to setting the Courser to a fixed position or make them invisibil
while the measurment is running. One thing about property nodes you should know, they are not very performant, so use them only
to initialization or deinitialization your processes.
Best regards
Lorenz Casper
(2,156 Views)
