Counting events using a USB-6008
I am using a USB 6008 as a simple counter.
I am using a relay to pull the counter input to gnd.
However I cant seem to get it to count just one time, ie sometimes it increases the count by one sometimes by 100.
What am I doing wrong, I am using the VI from the example folder and I have attached it below.
Tony
(4,389 Views)
Tony,
Relay contacts bounce.  That bounce may result in multiple openings and closings of the contacts over a few milliseconds for each operation of the relay.  The counter can count 100 ns wide pulses at up to 5 MHz so it may see all of the bounces as extra counts.  I think the 6008 counter circuit does not include any internal debounce options. So you will need to debounce with external circuits.  A simple resistor/capacitor low pass fitler might work, although the counter input circuit may not like the slow rise time.  A multivibrator configured as a pulse stretcher is another option.  There are many others.  Search the web for contact debounce circuits.
Lynn
(4,374 Views)
Thanks Johnsold,
I think I have solved it by taking the signal from my daqassist and putting it through a index array to trigger a case structure.
Within the case structure I have placed a delay, which allow time for the contacts to settle before incrementing the counter.
Thanks again.
Tony.
(4,355 Views)
Tony,
That is an interesting idea!  Always good to have multiple ways to solve a problem.
Lynn
(4,351 Views)
Could you please attach example of your solution.  How did you manage to make a delay for counter? You used ordinary DI and increment instead of counter input PFI0?
(4,318 Views)
