Control Test Stand
hi,
i have a main LabView VI which can starts Test Stand and run a sequence
now i need a break button in LabView who break Tast Stand and i need a answer from Tast Stand that he is in "break mode"
- how can i creat a break button in LabView?
- how can i get the answer.... whats the name of the property node?
thx for help
rabber
(3,442 Views)
rabber,
first of all, this question refers to TestStand, so you should post it in the TestStand forum.
Despite that, TS ships with examples for USER INTERFACEs. This is, what you are looking for.
Norbert
Norbert
Expert: Geometry
(3,438 Views)
i have to program this in LabView why it is a TS problem? TS has now problem!
(3,420 Views)
rabber,
i understand that the VI you got is already a TestStand UI. So it already loads TestStand and is able to load and execute sequences, correct?
In order to add a "break" functionality, you have to use the TestStand API. Therefore, you must be familiar with the "TestStand API for UI implemention", otherwise, you will likely fail to achieve your goal.
I have the impression, that you are not familiar with the TestStand API. My recommendation was to look at shipped examples in order to learn how to interface to TestStand from a VI.
Norbert
Norbert
Expert: Geometry
(3,413 Views)
so here the solution.... that was what i want to do 😉
(3,360 Views)
