Connect Hx711 in a NI USB-6009 or Arduino UNO in the Labview
Good day!
I have a a load cell, a hx711 ADC (photo attached), a NI USB-6009 and an Arduino UNO. So I intend to connect the load cell with the Hx711 in LabView using the NI USB-6009 Digital Input  or using Arduino UNO board.
I´ve already connect the load cell with Hx711 with the Arduino Software and works great. But I want to make it work with labview.
I need help.
Message 1 of 11
(7,059 Views)
Since you should be able to easily communicate to the arduino with LabVIEW, what is your exact problem? Are you using the Linx toolkit?
Message 2 of 11
(7,050 Views)
I don´t know how to program in labview with digital input. I need the block diagram. I´ve already have the arduino tool kit for labview.
Message 3 of 11
(7,036 Views)
And it is indifferent for me to use the NI USB-6009 or the Arduino UNO.
Message 4 of 11
(7,035 Views)
You said it was working fine with the arduino do what would be the point of switching to the 6009? How are you reading the value now with the arfuino ade?
Message 5 of 11
(7,025 Views)
Thanks Dennis for your concern and I understand your point view. I didn´t make myself clear.
The load cell is working fine with Arduino UNO in the arduino software, not in Labview. That´s what I want, to use the labview the acquisition data.
Because the output of Hx711 is digital, I don´t know how to program in Labview.
I only worked with analogic sensors.
Message 6 of 11
(7,008 Views)
I think you are completely missing the point. If you can read the arduino over its serial port, then you can do the exact same thing with LabVIEW. LabVIEW is not used to program the arduino. It is only used to send and receive commands/data over the serial port. The functions in LabVIEW for serial communication are VISA based. Look at the basic example.
Message 7 of 11
(6,999 Views)
I just want to read de values from the load cell in LabvIew.
Message 8 of 11
(6,984 Views)
The arduino is already reading the load cell. You just have to use the serial connection to read the arduino. What you get from a VISA Read should be identical to what you get from a serial read in the arduino ade. .
Message 9 of 11
(6,979 Views)
Hello , i have the same problem connecting my hx711 to Labview using NI daq. I want to connect it to Ni daq without an arduino. Any help with the code inLabview? Thank you in advance.
John Brew
Message 10 of 11
(6,376 Views)
